Honda Civic/Bypass clutch safety switch
crank12
Posted: January 30, 2004 at 3:43 PM / IP Logged
I just installed Ultra Start 2256M [Remote Starter/Security for manual transmission] Anyone can help me locate the right wire to tap the Starter Output. In the instruction it says "to the wire  from clutch safety switch that goes to the starter". I tried each one but never get started using the remote. [not to mention I have it set to reservation mode].. also the security and keyless entry are working just fine.. To anybody who had done this before please give me a hand. Thanks!!! Honda Civic/Bypass clutch safety switch -- posted image.
Vehicle Info: 1999 Honda Civic EX
technodigifreak
Copper - Posts: 50
Posted: January 30, 2004 at 8:34 PM / IP Logged
go to honda-acura.net and ask fro a wiring diagram
and don't tell them you are hooking up a remote start on a manual--you'll get majorly flamed
Hot-Modder
whitey
Member - Posts: 49
Posted: February 14, 2004 at 10:35 AM / IP Logged
at the clutch swithch there is a blue/black wire.  Hook your status - out when running to this wire.   Hook your starter output wire from the unit up to the BLACK/ white  wire at the igniton harness.
That will make it work
Visions Edmonton
Installation Manager, DLS
MECP Certified First Class
