2003 Yukon Denali remote start
playhardaudio11
Posted: January 30, 2004 at 5:20 PM / IP Logged
I am havinh a difficult time finding the brake wire which is suppose to show +12 volts when the brake pedal is depressed. I have one diagram that says it is a white wire at the brake switch but when I hooked it up and activated the remote start the truck would not shut off be pressing the brake. A new problem has arose though. Now the brake lights don't work nor the cruise. I am wondering if anyone knows what color harness this white wire is in, it's location, and how many and what color the other wires are?
jrilla
Gold - Posts: 1,498
Posted: January 30, 2004 at 5:49 PM / IP Logged
Well did you test the wire before you hooked it up? If you disconnected the wire, and it still doesnt work, then you probably blew a fuse.
Be sure to test the next wire before you hook it up again.
J Rilla
Owner/Installer
prdjr165
Copper - Posts: 293
Posted: January 30, 2004 at 6:07 PM / IP Logged
It's suppose to be a white wire at the brake pedal switch,Always check with a DVM before connecting your wire!You probably blew a fuse.
