remote start on a manual
rudbwoy69camaro
Silver - Posts: 350
Topracer
Posted: February 08, 2004 at 7:57 PM / IP Logged
Steven Kephart wrote:
My Clifford alarm is designed for a manual, has been installed for 4 years now and I have never had a problem.
Steven - What model Clifford do you have?  I am interested in adding something to my Cobra, but haven't had any luck finding it on Cliffords site.  Thanks.
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: February 11, 2004 at 12:35 AM / IP Logged
I have an old school Clifford Ace 7500.  I bought it about 4 years ago when I worked at Circuit City.
S.I.Autosports
Copper - Posts: 98
Posted: February 11, 2004 at 6:11 AM / IP Logged
I have seen people use a reed switch (used in home security) mounted to the shifter rod inside the console so that the two magnets only come in contact when in the neutral position.  You can wire it to the hood safety switch.
jgold47
Copper - Posts: 69
Posted: February 11, 2004 at 6:42 AM / IP Logged
that can work on some cars, it just depends on the layout of the console, etc...we have tried that on my old car (integra) and had no luck, I have also heard of trying that down at the linkage, etc....
but listen to my idea for a sec, I want your opinions....
1 switch mounted by the shifter
switched ground...
other side goes to....
2 relays, wired backwards of eachother, one normally open the other normally closed
relay one 1. interrupts neutral saftey wire when open
relay two interrups brake shutdown wire when closed.
so....switch disconected  or up.....NSW is conected, car can be remote started but brake shutdown is not active so you cant release the car......
switch connected....brake wire reconnects, allowing you to shut the rmote starter down, but the nsw is disconected so you cant remote start the car....
unless you flip the switch back the other way, which, if its by the sh*ter will undoubtedly be  a reminder to put the car in neutral....what do you think???
Steven Kephart
Posted: February 11, 2004 at 9:44 AM / IP Logged
I have heard of that as well, but highly recomend against it.  I used to work for Sonitrol installing alarms, and sometimes we used to have to replace those switches after a while.  Their great for alarm triggers where if they fail, it just makes a lot of noise.  But for this if it fails, it is much more serious.  Just an FYI.
