Hood pin switch location
cpgoose
Gold - Posts: 1,098
Posted: August 08, 2002 at 7:49 AM / IP Logged
Does anyone have a picture of their hood pin switch install?
Just curious where the best place is to put it...it terms of:
 - in the front or rear of engine bay
- best place to avoid water and moisture buildup
- so the hood hits it nicely, or do you have to customize it so it hits the pin
Gentleman
Copper - Posts: 71
Posted: August 08, 2002 at 9:40 AM / IP Logged
Based on advice I received in this forum I purchased a mercury switch from http://store.autotoys.com , mounted it to the hood itself and don't have to worry about water getting into a pin switch.
cpgoose
Gold - Posts: 1,098
Posted: August 08, 2002 at 12:54 PM / IP Logged
ok, so if I don't want a mercury switch, does someone have ideas on my first post?
Platinum - Posts: 12,488
Posted: August 08, 2002 at 7:05 PM / IP Logged
Depends on the vehicle. All vehicles have a " sweet spot " that will depress the hood pin switch properly. If nothing else you will need to install an " L " bracket to support a location that the hood will touch the oin switch.
cpgoose
Gold - Posts: 1,098
Posted: August 10, 2002 at 10:28 AM / IP Logged
Cool, thanks.
Can I ask now how to hook the wire up to it?
Do I have to use a male connector at the end of the wire,
and plug it into the switch, or is there a different way?
Here's the switch:
Hood pin switch location -- posted image.
Friday, February 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
