Unlock Wire (99 Grand Am)
Trav3D1
Copper - Posts: 146
Posted: February 10, 2004 at 10:32 PM / IP Logged
I recently installed a Prestige APS-25CH in a 1999 Pontiac Grand Am.  I have located the single (white) power lock and unlock wire and installed a 1.5 K ohm resistor on the unlock wire as required.  I am still having problems with the unlock function of the alarm.
Does the unlock wire need a double ground pulse?  Any suggestions
In addition, any information on the door triggers would be helpful also. (i.e. wire color, location, and installation specs.)
Trav
ccroadshop99031
Copper - Posts: 102
Posted: February 10, 2004 at 10:36 PM / IP Logged
is it 1.5.  or 15k id dubble check
Trav3D1
Copper - Posts: 146
Posted: February 10, 2004 at 10:45 PM / IP Logged
Here's the resistor color (4 band) code that I was using from right to left.
Brown, Green, Red, Gold = 1.5K
Trav
mobiletoys2002
Gold - Posts: 1,050
Posted: February 10, 2004 at 10:59 PM / IP Logged
did you use relays??? If not use them this sytem cannot be hooked up directly withouit relays tehy are negative but need a high current ground to work!!! the unlock requires a 1.5k ohm resistor !
sroth140
Silver - Posts: 513
Posted: February 11, 2004 at 12:51 AM / IP Logged
you have to use relays.  its a one wire door lock system.
Trav3D1
Copper - Posts: 146
Posted: February 11, 2004 at 6:38 AM / IP Logged
I have the lock wire hooked up directly, and it works fine.  Will only the unlock wire require the relay? and if so is there a particular wire spec. I should follow or should the traditional "actuator" specs with the resistor added work just fine?
Trav
mobiletoys2002
Gold - Posts: 1,050
Posted: February 11, 2004 at 8:36 AM / IP Logged
wire your relays as follows take the negative output from the alarm for lock put that on pin 85, take 12 volts positive (depending on alarm the unit may have this in the door lock harness)and put on in 86.
Pin 87 will get ground, pin 30 will go to the white wire in the car.
You do the same thing for unlock but this time place the resistor on the wire at pin 30!!!
