Remote Start 5-speed
TeamMobileNyc
Member - Posts: 8
Posted: February 10, 2004 at 11:15 PM / IP Logged
I know it's highly not recomended but  what wouold be the safe way to put a remote atart on a manual? Magnetic reed switch, brake wire ??? Has anyone done it? Thanks for the advise!
kfnyc
Dreadlock
Copper - Posts: 55
Posted: February 10, 2004 at 11:35 PM / IP Logged
check dealer scematics to see if the vehicle in question has a neautral safety switch. that may be accesable at the ecu and trans. some cars have theese others do not. sometimes there rigth in the diagnostics port of the car. And use the E brake wire.
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: February 11, 2004 at 12:06 AM / IP Logged
That's good to know Dreadlock.
Also check into an item made by Peripheral called an NSS or "Neutral Safety Switch".  The remote start you install will have to have the "stop and go" feature for this to work though.  But what it does is monitor the doors.  You open a door, it won't start.  You will find it at the bottom of the page of this link: http://peripheralelectronics.com/2002/security_bypasses.asp
S.I.Autosports
Copper - Posts: 98
Posted: February 11, 2004 at 6:13 AM / IP Logged
I have seen the reed switch used many times.
Tmanrealone
Member - Posts: 14
Posted: February 11, 2004 at 8:39 AM / IP Logged
Can remote start mess up your starter or anything else in your car
mobiletoys2002
Gold - Posts: 1,050
Posted: February 11, 2004 at 8:45 AM / IP Logged
Not if hooked up correct. When you hook it up make sure you get all ignition wires(ie first ignition, second ignition,etc)!!! Also I would recomend usng a tach reference for the remote starter not voltage sensing.
If done correct this unit will last you years without worries and your car wont chabge a bit!Remote Start 5-speed - Last Post -- posted image.
If you are gong to install your self post back with any questions you may have. Good luck
jgold47
Copper - Posts: 69
Posted: February 11, 2004 at 8:47 AM / IP Logged
reed switch only works on certain cars...some cars there is too much room between amounting point and the switch etc...
check out this post....
I had an idea for this,...kinda like the stop and go idea....
https://www.the12volt.com/installbay/forum_posts.asp?tid=25873&PN=1
VWTim
Posted: February 11, 2004 at 8:47 PM / IP Logged
Im very interested in anyones reed switch setup.  Any pictures no matter how horrible.  This is going in my car, to make it gf proof :)  So I don't have to worry about liability.
thanks,
Dreadlock
Copper - Posts: 55
Posted: February 13, 2004 at 5:18 PM / IP Logged
elaborate more on this stop and go feature, and how the doors have anything to do with it.
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
