aux channel
dwjack
Member - Posts: 6
Posted: February 14, 2004 at 8:06 AM / IP Logged
I installed the Viper 791xv and everything was fine.  Yesterday I added a DEI trunk pop solenoid and wired it to the alarm with a relay according to the DEI installation instructions.  RED / White 85, fused 12V 86, 12V 87, +solenoid 30.  Everything went fine and it worked without any problems.
When I was moving wires around to put it all back I heard a pop and now the aux channel doesn't work.  I think power might have touched the RED / white wire, I accidentally had one exposed close to the relay output.  Testing that wire it shows ground when activated which is right.  All other wires for the relay test fine but it still won't work.
I switched to Channel 4 output, violet and it worked fine, just like before.  My question is did I screw up the channel 2 output somehow and if so why do I still get ground from it when testing.
whitey
Member - Posts: 49
Posted: February 14, 2004 at 9:33 AM / IP Logged
Try unpluging the the brain for the 791xv.  Then take a knife or screw driver and short all the pins on the main harness together to discharge all the caps on board.
Plug it back in and try it.
Visions Edmonton
Installation Manager, DLS
MECP Certified First Class
dwjack
Member - Posts: 6
Posted: February 14, 2004 at 10:25 AM / IP Logged
short all the pins on the brain side or the plug side?
whitey
Member - Posts: 49
Posted: February 14, 2004 at 10:44 AM / IP Logged
brain side.  Make sure all wires are disconected form the unit
Visions Edmonton
kgerry
Platinum - Posts: 3,455
Posted: February 14, 2004 at 1:56 PM / IP Logged
you may have blown the Aux output and still have it show a bit of ground...i have seen some with a hole blown thru this transistor yet it will still work slightly..its when it has to generate a bit of current that it fails....
dwjack
Member - Posts: 6
Posted: February 14, 2004 at 7:40 PM / IP Logged
Now what?  I tried disconnecting the brain, opened it up but didn't see anything unusual.  If I did blow the Aux output is there anyway to combine the silent chirp and channel 4 both onto the Aux buttom of the remote?
Wednesday, November 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
