factory bypass ?
perm79
Posted: February 18, 2004 at 4:52 AM / IP Logged
i have a 91 acura legend sadan and i bought a keyless entry . i want to iinstall but im wondering if the car already has what im going to install or not and if i have to bipass any thing. newby thanks
boomer_106
Silver - Posts: 710
Posted: February 19, 2004 at 12:27 PM / IP Logged
Acura
Legend Sedan
1991-1993
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ WHITE
IGNITION SWITCH HARNESS
Ignition  #1:
BLACK / YELLOW
Ignition #2:
YELLOW
Ignition  #3:
N/A
Accessory:
WHITE/ RED
Brake  Light:
GREEN / WHITE (+)
SWITCH ON BRAKE PEDAL BRACKET
Tach  Signal:
BLUE
AT TACH TEST CONNECTOR *
Parking Lights:
RED / BLACK (+)
DRIVER KICK PANEL
Headlights:
BLUE/RED (-)
HEADLIGHT SWITCH OR AT RELAY
OEM Alarm  Disarm:
GREEN/ RED (-)
SECURITY MODULE UNDER DRIVER'S DASH
OEM Alarm  Arm:
GREEN/ YELLOW (-)
RIGHT SIDE OF STEERING WHEEL
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Tach Test Connector (2 Pin White Plug) Is Located On Passenger Rear Of Engine Compartment On Passenger Strut Tower.
Acura
Legend Sedan
1991-1993
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE
Starter  Kill:
BLACK/ WHITE
Ignition  +12 Volts:
BLACK / YELLOW
Dome  Lights/Superv:
BLACK/ WHITE (-)
DRIVER "B" POST
OEM Horn:
BLUE/RED (-)
PIN # 8 OF # PIN CONN. OF SECURTY MOD
Power  Lock:
GREEN / WHITE (-)
AT DOOR LOCK MODULE BEHIND DRIVER'S
Power  Unlock:
GREEN/ RED (-)
DASH TO RIGHT OF STEERING COLUMN**
Trunk  Release:
WHITE/ BLACK/ GOLD DOTS
(+) DRIVER'S KICK ***
Alarm  Input Wire:
BLACK/ WHITE (-)
DRIVER "B" POST
Notes:
** See Note #201- Negative Pulse Door Lock Diagram. *** See Note # 232 Positive
Teamrf
Gold - Posts: 1,031
Posted: February 19, 2004 at 7:20 PM / IP Logged
From the tech sheet someone posted doesn't look like you have any bypassing to do. Goodluck...
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
perm79
Posted: February 28, 2004 at 5:19 PM / IP Logged
thanks,
 is this all i need to do for install? do i need to disable factory alarm? do i need to run any relays?
thank for the help
boomer_106
Silver - Posts: 710
Posted: February 28, 2004 at 7:56 PM / IP Logged
Ya according to the sheet you need to disarm the factory alarm.  You can see it listed as OEM alarm disarm. If you dont when you open your doors the alarm will go off. Whether you need relays depends on the keyless system you bought. You should have stated what it was and you may have gotten more help. To get the best help always give the make and model of the system as well as the make and model for the car. The instructions that came with it will probably tell you. Good luck
