03 Dakota Power Windows
Big game
Member - Posts: 12
Posted: February 20, 2004 at 6:22 PM / IP Logged
I just installed Keyless Entry and remote Start about a week ago.  Everything works fine, and I am pretty happy with it.  Today I tried to roll down the window, and the stupid thing isn't responding, and to top it off, none of the passenger windows are working.  The door lock on all the passenger doors work, but the driver side is dead.  The remote locks work as well.  I checked the amp for the power windows under the hood, and it seems fine.  Any suggestions would be greatly appreciated.
Thank you.
Mike's Bikes
Carson, CA
Platinum - Posts: 12,488
Posted: February 20, 2004 at 6:44 PM / IP Logged
Disconnect the sentry bypass module and test the windows. Post your results.
Big game
Member - Posts: 12
Posted: February 20, 2004 at 10:20 PM / IP Logged
Thanks, but where might that be?  Is that where the Wires come into the kick panel computer?
Mike's Bikes
Carson, CA
Posted: February 20, 2004 at 10:50 PM / IP Logged
Sorry, I thought that you installed the system. The module will be a small black box in the driver's dash area. It will not look factory and one wire will be connected to the data wire on the diagnostics plug. Follow this wire to the module and unplug this module.
Big game
Member - Posts: 12
Posted: February 20, 2004 at 11:24 PM / IP Logged
Yea, I did install the remote Start and Keyless Entry, but the Electrical Lingo is a bit confusing to me.  I will follow the wire from the Diagnostic plug to the CTM (Central Timer Module), but there are three plugs?  Which one should I test?  Do you know the color codes?  I don't want to waste too much of your time, I know you have allot of people to help.  Should I just take it back to the dealership, and have them fix it?  I bought a bumper to bumper, but I might have voided the Warranty when I installed the Remote Starter and Keyless.  If they open that bottom panel and see what I've done down there, they will flip out.  It looks like a dang rat nest of wires, so I was hoping if anyone new of a quick fix, i.e. fuse, loose connection, or relay.  The windows worked fine last night, and today they just quit on me.  There was no smell of burning wires, or anything.  I really appreciate your help Jeff, but I am still one confused feller.
Thanks for your help and info so far,
Mike
Mike's Bikes
Carson, CA
Big game
Member - Posts: 12
Posted: February 22, 2004 at 10:45 AM / IP Logged
Ok, I found the problem.  The plug that connects to my Window Switch must have come loose and then disconnected.  All I had to do is plug it back in.  Remember to start from the source, and then work your way down.  Never start in the middle, and work yourself over.  Anyways,  thanks for the attempted help Velocity Motors.  At least I saved my self time and didn't have to take it to the dealership.
Mike's Bikes
Carson, CA
