2001 jeep + cheap radio= junk
beyondamfm
Copper - Posts: 105
Posted: February 21, 2004 at 8:34 AM / IP Logged
I have a customer come in with a 2001 jeep grand cherokee yesterday and wanted me to install a cheap legacy cd player in it. not a problem, quick $40.00.  Well I got it in and let him go he can back about 10 minutes later and said it doesn't get good reception, so I took it around the block and he was right, some stations had really bad static I check all conections and they were fine, original radio was also fine so I think it was the cheap legacy radio. What do you guys think?  thanks
The Clear Bra Guy
KCs premiere paint protection guru
DYohn
Platinum - Posts: 10,741
Posted: February 21, 2004 at 10:40 AM / IP Logged
Does this vehicle use an amplified antenna? If so it is probably no longer being powered.  Otherwise it is possibly just a crappy receiver in the new HU.
beyondamfm
Copper - Posts: 105
Posted: February 21, 2004 at 2:49 PM / IP Logged
That was the first thing I check for and it does have a powered antenna, but it is hooked up.2001 jeep + cheap radio= junk -- posted image.
The Clear Bra Guy
auex
Platinum - Posts: 5,041
Posted: February 21, 2004 at 4:06 PM / IP Logged
The topic should read "Cheap radio=junk". Just in case it is not the radio there should be an antenna break in the glove box or passenger kick panel, you should check to see if the antenna came loose there.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
