aftermarket 5 wire door locks
Koolaid421
Member - Posts: 22
Posted: February 24, 2004 at 8:02 PM / IP Logged
i m having proble,s hooking up my 5 wire central locking power door locks to my remote start. the remote start is a DirectStart 423 with built in keyless entry. i need to know who to hook the door locks to the unit  thanks for the help
hell yea
draasch
Gold - Posts: 2,172
Posted: February 24, 2004 at 8:12 PM / IP Logged
what brand of CDL do you have....
most of them have two wires that are neg trigger wires.
if you ground them, they will operate each way..they may show 12v until you operate the locks.
you should be able to hook up to those wires.
you will need a neg door lock output from the alarm.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Koolaid421
Member - Posts: 22
Posted: February 24, 2004 at 8:22 PM / IP Logged
hey the kit is a spal model 148 if that help u any
hell yea
draasch
Gold - Posts: 2,172
Posted: February 24, 2004 at 8:38 PM / IP Logged
i think you will have a purple and brown wire.
check those wires for proper hook up...
Good Luck
David
Ace Security
813-376-9778
Tampa
Koolaid421
Member - Posts: 22
Posted: February 24, 2004 at 8:42 PM / IP Logged
there is a purple and brown is that the wires i use
hell yea
draasch
Gold - Posts: 2,172
Posted: February 24, 2004 at 8:43 PM / IP Logged
use a meter to check the wires
Good Luck
David
Ace Security
813-376-9778
Tampa
Koolaid421
Member - Posts: 22
Posted: February 24, 2004 at 8:46 PM / IP Logged
so should they be + or -
hell yea
Koolaid421
Member - Posts: 22
Posted: February 24, 2004 at 9:23 PM / IP Logged
do i have to hook up both driver and passenger side or just 1 side
hell yea
draasch
Gold - Posts: 2,172
Posted: February 24, 2004 at 9:39 PM / IP Logged
just one side......they may read 12v and then go to ground when you operate the door locks......
Good Luck
David
Ace Security
813-376-9778
Tampa
NowYaKnow
Gold - Posts: 1,217
Posted: February 24, 2004 at 9:50 PM / IP Logged
Not familiar with that model of spal but generally those spal central locking kits come with the actuators themselves and a small relay box. If you look at the plug on the relay box there will be a thin brown wire and a thin purple. Each pin should have 2 of the same color wire stuffed into it (meaning 2 browns are in one pin and 2 purples are in another pin). You want to use the brown and purple wires (-) to tap your keyless entry module wires into. Be sure to test first and make sure they are the correct wires and determine which is which. And since they are both stuffed into the same pin and are a central locking kit you only need to tap one of them no need for both driver and pass. Good luck,
Mike
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
