98 Dakota Power Door Locks
robbain
Member - Posts: 23
Posted: February 25, 2004 at 11:17 AM / IP Logged
I'm installing a Crimestopper CS2015FM TW1 in my 1998 Dakota. I'm trying to figure out how to hook up the power door locks. I think they are reverse polarity and require extra relays. Any help or diagrams would be greatly appreciated. Thanks.
Rob
robbain
Member - Posts: 23
Posted: February 25, 2004 at 11:21 AM / IP Logged
Also, the vehicle has factory power locks but no keyless entry. Thanks.
Rob
draasch
Gold - Posts: 2,172
Posted: February 25, 2004 at 12:20 PM / IP Logged
what are the outputs on the alarm????
Power Lock ORN/PPL OR GRN/BLK 16 PIN CONNECTOR BEHIND ** #203
Power Unlock PINK/VIOLET FUSE BLOCK IN DRIVER KICK PANEL
203 - See Reversal Rest At Ground Door Lock Diagram W/Or WO Keyless.
http://wiringinstructions.com/203.htm
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
davedyer79
Copper - Posts: 178
Posted: February 25, 2004 at 12:31 PM / IP Logged
A little easier wiring diagram.  The diagram that draasch sent is for a DLS plug from Omega, which would make the connections a lot easier.  If you do not have the DLS, grab two SPDT relays from the automotive store or Circuit City and wire the like this diagram
https://www.the12volt.com/doorlocks/page3.asp#5w
This will work if the outputs of your alarm is negative outputs, which it should be.
Good luck.
davedyer79
Sandungero24
Member - Posts: 44
Posted: February 26, 2004 at 3:32 PM / IP Logged
robbain
Member - Posts: 23
Posted: February 26, 2004 at 3:59 PM / IP Logged
Another thing I noticed on the wiring diagram was that it lists BLACK/ orage for accessory and for ignition 2. Does this mean there are two BLACK/ orage wires? or do I just use it for the accessory and there is no ignition 2? Thanks.
Rob
draasch
Gold - Posts: 2,172
Posted: February 26, 2004 at 4:05 PM / IP Logged
Remote Start
Tach Signal BLACK/ GRAY AT IGNITION COIL *
Ignition #2 BLACK/ ORANGE IGNITION SWITCH HARNESS (HEAT/AC)
Ignition #3 N/A
Accessory BLACK/ WHITE IGNITION SWITCH HARNESS
Neutral Safety BLACK/ WHITE (-) AT POWERTRAIN CONTROL MODULE **
Brake Light WHITE/ TAN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light VIOLET/BLACK (+) AT SWITCH ON TRANSMISSION
Rear Window Defrost N/A
* Ignition Coil Is Located On Passenger Front Of Engine. BLACK/ GRAY Wire Is Also Located At Powertrain Control Module (PCM) In A Black 32 Pin Connector. ** Powertrain Control Module (PCM) Is Located On Passenger Rear Of Engine Next To Strut Tower.
Good Luck
David
Ace Security
813-376-9778
Tampa
daniel2002p
Silver - Posts: 524
Posted: February 26, 2004 at 8:00 PM / IP Logged
your locks are reverse polarity, but BLACK/ orange is acc and lt blue is ignition.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
robbain
Member - Posts: 23
Posted: February 26, 2004 at 9:30 PM / IP Logged
One person tells me that BLACK/ orange is ign 2 and somebody else says it is acc. I've been told that dk blue is ign, now it's lt blue. Who is right???
Rob 1998 Dakota
Sandungero24
Member - Posts: 44
Posted: February 26, 2004 at 9:32 PM / IP Logged
Ignition 1Dark Blue Ignition Switch Harness
Ignition 2BLACK/ Orange Ignition Switch Harness (Heat/AC)
AccessoryBLACK/ Orange Ignition Switch Harness
