How to bypass original alarm Urgent
reycoliman
Posted: February 26, 2004 at 8:09 AM / IP Logged
I need to bypass the original Ram 2500 (V8 Magnum) pickup 1998.
Any help....
Thanks in advance
draasch
Gold - Posts: 2,172
Posted: February 26, 2004 at 8:21 AM / IP Logged
here is all i have...
Make:   Dodge
Model: Pickup - Fullsize
Year:    1998
This Database Was Last Updated On:    6/9/2003
Index #: 344
Alarm
Constant 12 volts RED & PINK/BLACK IGNITION SWITCH HARNESS
Ignition 12 volts D BLUE IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light YELLOW (-) 26 PIN CONNECTOR BEHIND DRIVER DASH
Trunk Pin Switch N/A
Parking Lamp BLACK / YELLOW (+) 74 PIN CONNECTOR BEHIND DRIVER DASH
Power Lock ORANGE / VIOLET 10 PIN CONNECTOR IN ACCESS #203
Power Unlock PINK/VIOLET HOLE IN DRIVER KICK PANEL
#203 - See Reversal Rest At Ground Door Lock Diagram.
View Diagrams
Accessories
Window Up D\ L BLUE P\ BROWN / WHITE @ MAIN #211
Window Down R/ WHITE S/ VIOLET/WHITE SWITCH
Ign Key Warn L BLUE (-) IGNITION SWITCH HARNESS
Trunk Release N/A
OEM Horn BLACK/ RED (-) 74 PIN CONNECTOR BEHIND DRIVER DASH
Headlights L GREEN/ BLACK (-) AT HEADLIGHT SWITCH
OEM Alarm Arm N/A
OEM Alarm Disarm L GREEN/ ORANGE (-) 24 PIN CONNECTOR BEHIND DRIVER DASH
#211- See Reversal Rest At Ground Power Window Circuit Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
reycoliman
Posted: February 26, 2004 at 12:24 PM / IP Logged
The info you have sent to me
was the info I had, but didnt work
seems to be at least 3 models of alarms for this pickup
thanks anyway
rubalex1
Member - Posts: 7
Posted: February 27, 2004 at 7:40 AM / IP Logged
See if you can find a GREEN/ violet wire going into the driver's door, or at the module itself. this wire will need a 470KOHM resistor with a positive trigger to disarm the factory alarm. I have installed plenty of aftermarket alarms on Chrysler vehicles and this seems to be a common color for a factory disarm wire.Give this a shot and lots of luck!
Ruben Giraldo
Atlanta GA.
Test twice, tap once!
Always double check your wires, and not only rely on what the schematics say.
daniel2002p
Silver - Posts: 524
Posted: February 27, 2004 at 7:50 AM / IP Logged
providing ground to the GREEN / WHITE wire should disarm the factory alarm system, but it should only need that if you have a grey key.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
rubalex1
Member - Posts: 7
Posted: February 27, 2004 at 8:40 AM / IP Logged
Sorry, I may be wrong on the positive trigger part, yes it is a negative trigger. But this doesn't only apply to vehicles that have a grey key ( with a transponder inside of it). I don't think back in 1998 crhysler vehicles came with OEM grey keys.
Ruben Giraldo
Atlanta GA.
chriswallace187
Gold - Posts: 1,661
Posted: February 27, 2004 at 1:11 PM / IP Logged
2 suggestions:
On Chrysler trucks I've seen both factory alarms, and dealer installed keyless entry upgrade alarms(that are similar to aftermarket alarms exc. they work off of the factory keyless entry remote, or the lock switch).
If yours is a factory alarm, there will be a wire coming from the driver's door into the car(most likely the light GREEN/ orange) that will show 12v at rest and go to nothing when the key is turned to unlock in the driver's door key cylinder. A negative pulse to that wire will disarm the system.
If it's a dealer installed keyless upgrade alarm, you will need to find the brain for it. There will be a wire there that will show 12v whenever the unlock switch is pushed or the unlock button on the transmitter is used. In order to disarm this type of system you will need to send 12v+ to the disarm wire, and use a diode or relay to isolate it from the unlock motor lead.
