2000 Ford Contour Firewall
gq_4
Member - Posts: 8
Posted: February 28, 2004 at 3:00 AM / IP Logged
The last time I did a post was regarding a 1998 Taurus.  Had too many problems with it and now I am looking at a 2000 Ford Contour.  My question is....how hard is it to find a hole in the firewall to run my amp wire through?
Ketel22
Silver - Posts: 976
Posted: February 28, 2004 at 3:10 AM / IP Logged
in most cars you can use an existing grommit that is in the fire wall on the passenger side in the top right corner, midfire-wall, or on the driver side top left corner.
Quad L Handyman services
gq_4
Member - Posts: 8
Posted: February 28, 2004 at 3:14 AM / IP Logged
I tried that with the Taurus and it was a nightmare.  I could not find a hole anywhere.  I had to run the wire along side the door and though the fender well into the car.  Had to remove tire and the covering.  I just want to make sure that there will be an easier way than that.
Clean Install
Silver - Posts: 446
Posted: February 28, 2004 at 10:18 PM / IP Logged
Is there no where to drill a hole then place a gormet, use a punch and check to see where the punch was made and see if its a safe place to drill...
I would not run it out the door through the wheel well, thats just me though...
Good Luck
If we learn from each success and
each failure, then we can improve ourselves
Clean Install
Silver - Posts: 446
Posted: February 28, 2004 at 10:21 PM / IP Logged
I knew a guy one time that just drilled a D*mn hole in his Floor board, in plane sight...
 looked great,2000 Ford Contour Firewall -- posted image.
gq_4
Member - Posts: 8
Posted: February 29, 2004 at 3:11 AM / IP Logged
I purchased the car today and will start looking for the hole first thing in the morning.  If I can't find the gromet that will give me the quick access I need, so help me I will drill.  Thank you guys for the info.  If you find out anything else on this, please let me know.  This place is the best site for info.
NINsane18
Copper - Posts: 103
Posted: February 29, 2004 at 4:25 PM / IP Logged
I had the same problem on my Grand Cherokee. Crutchfield sells bushings that work awesome when going through the firewall. I was impressed how well they worked. Here is a link to them: http://www.crutchfield.com/S-NFp4jU80BML/cgi-bin/ProdGroup.asp?c=11&s=0&g=65400&cc=01&avf=N&search=
Scroll down to the bottom and there they are. Good luck, and remember, look very carefully before you drill. I drilled a small pilot hole to make sure everything was center and clear before drilling the larger hole.
Tim-May!
harvey1959
Copper - Posts: 94
Posted: March 02, 2004 at 5:50 PM / IP Logged
I normally punch a hole through the rubber grommet where the hood release goes through and insert the cable through it.
Harv
A Lobo
Posted: March 02, 2004 at 7:40 PM / IP Logged
look for a teardrop shaped grommet on the drivers side firewall.
auiotour
Posted: April 05, 2004 at 9:59 PM / IP Logged
Try those, these are from my 99 se sport. Some drilling required, through multipul pieces. If you wanna know more information about contours. check out contour.org, fordcontour.org. Check the audio sections.
