Posted: February 29, 2004 at 1:14 AM / IP Logged
Posted: February 29, 2004 at 7:34 AM / IP Logged
Function | Vehicle Color | Location | |
Start: | |||
Ignition #1: | |||
Ignition #2: | |||
Ignition #3: | |||
Accessory: | |||
Brake Light: | |||
Tach Signal: | |||
Parking Lights: | |||
Headlights: | |||
Diesel Glow Plug: | |||
Clutch Bypass Wire: | |||
NOTES |
Alarm and Keyless Entry Wiring Colors |
Constant +12 Volts: | WHITE/ Red | Ignition Switch Harness | |
OEM Alarm Disarm: | Green(-) | At ECU | |
Dome Lights/Superv: | Green(-) | In Driver Kick Panel | |
OEM Horn: | GREEN/ Red | In steering Column Harness | |
Power Lock: | Pink/Black | At Switch Inside Driver Door | |
Power Unlock: | Pink/Grn/Gry | At Switch Inside Driver Door | |
Trunk Release: | Purple (-) | At Trunk Release Switch | |
Alarm Input Wire: | Green(-) | In Driver Kick Panel | |
NOTES |
