sub wiring question
gumby_55
Member - Posts: 38
Posted: March 01, 2004 at 10:08 AM / IP Logged
{TABLE id=HB_Mail_Container height="100%" cellSpacing=0 cellPadding=0 width="100%" UNABLE="on"}{TR height="100%" UNABLE="on" width="100%"}{TD id=HB_Focus_Element vAlign=top width="100%" background=""0 UNABLE="off"}What would be the best way to wire 4 power acoustik fubr 10's to a power acoustik OV2-1600 power acoustik amp. The amp is 310 x 2 RMS@ 4 ohms, 370 x 2 RMS@ 2 ohms, and 740 x 1 RMS mono. But is only 2 ohm stable stereo. The subs are dual 2 ohm voice coil.{/TD}{/TR}{TR UNABLE="on" hb_tag="1"}{TD style="FONT-SIZE: 1pt" height=1 UNABLE="on"}{DIV id=hotbar_promo}{/DIV}{/TD}{/TR}{/TABLE}
gumby_55
Member - Posts: 38
Posted: March 01, 2004 at 10:13 AM / IP Logged
{TABLE id=HB_Mail_Container height="100%" cellSpacing=0 cellPadding=0 width="100%" UNABLE="on"}{TR height="100%" UNABLE="on" width="100%"}{TD id=HB_Focus_Element vAlign=top width="100%" background=""0 UNABLE="off"}{p}What would be the best way to wire 4 power acoustik fubr 10's to a power acoustik OV2-1600 power acoustik amp. The amp is 310 x 2 RMS@ 4 ohms, 370 x 2 RMS@ 2 ohms, and 740 x 1 RMS mono. But is only 2 ohm stable stereo. The subs are dual 2 ohm voice coil.{/p}{p}Sorry, I don't know what happened the last post, but it wasn't on purpose.{/p}{/TD}{/TR}{TR UNABLE="on" hb_tag="1"}{TD style="FONT-SIZE: 1pt" height=1 UNABLE="on"}{DIV id=hotbar_promo}{/DIV}{/TD}{/TR}{/TABLE}
DYohn
Moderator - Posts: 10,741
Posted: March 01, 2004 at 3:53 PM / IP Logged
The only safe way to wire a set of 2-ohm DVC subs to that amplifier is to wire them for 4-ohms (both VCs in series) and connect them to the amp in stereo.  (4-ohm load on each channel.)  It is not a great match.
wvsquirrel
Gold - Posts: 1,237
Posted: March 01, 2004 at 6:48 PM / IP Logged
I agree with DYohn, this isn't a good match at all. You'll only get the 310 watts per sub since you'll be providing a 4ohm load to each channel. But that's your only safe wiring with this setup. Here's how each sub should be wired per channel...
sub wiring question -- posted image.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
Wednesday, November 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
