1995 Accord Power Antenna
dmwildberger
Member - Posts: 14
Posted: March 03, 2004 at 7:57 PM / IP Logged
I have a 1995 Honda Accord EX Sedan, and I am trying to replace my factory AM/FM Cassette Stereo with a Pioneer DEH-1500 receiver. My Accord has a power antenna in the rear that works with the factory stereo; it goes up and down when the radio is on /off. However, my Pioneer head unit's wiring harness doesn't seem to have a wire lead to operate the power antenna. Where can I connect the power antenna lead from my car to my new head unit so that it will operate normally. I want it to be able to retract when I turn off my radio. Can I just connect it to the ACC / IGNITION + (Red), or some other power source?
Any suggestions?
Thanks,
dmwildberger
Maxst
Silver - Posts: 866
Posted: March 03, 2004 at 8:00 PM / IP Logged
Put it on the 12volt turn on lead, if you have an amp you'll tap into that wire as well....its usually blue and has a plastic tag.
I need quality equipment, feel free to donate.
profuse007
Gold - Posts: 2,015
Posted: March 04, 2004 at 1:47 AM / IP Logged
use the blue/white wire, to be exact
Houston,TX
forbidden
Platinum - Posts: 5,354
Posted: March 04, 2004 at 1:58 AM / IP Logged
What are you still doing up at this hour?
Thursday, January 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
