Need help with durango fog lights
jmhayden
Posted: August 16, 2002 at 5:06 PM / IP Logged
My 99 Durango's fog lights dont come on.  When I probe the wires to the lights it reads +12v on both wires.
Everythig else works fine.  Anyone have any thoughts?
Sound Pressure
Silver - Posts: 711
Posted: August 16, 2002 at 11:20 PM / IP Logged
Blown bulbs? Take them out and check the filaments on them to see if they are broken in the center. Or as simple as the switch for them being turned off accendently, hey it happens to the best of us. Post your results.
Sound Pressure
jmhayden
Posted: August 20, 2002 at 8:49 PM / IP Logged
Let me give a little more information:  I unplugged the connector and checked the continuity and voltage at both the wires.  The solid blue has +12v and the blue with black stripe has +12v.  When I turn the switch on nothing changes.  I found out that the blue with black stripe is supposed to go neg. when lights are on.  But it doesn’t.  I also tried to replace the relay.  Same result.  The only thing I haven’t replaced it the switch.  (That is a very expensive part)
Ideas?
Sunday, November 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
