94 honda accord ex Parking lights
Primo8998
Posted: March 15, 2004 at 2:44 PM / IP Logged
OK i have a Hornet 553t.  When the alarm goes off the parking lights flash.   The problem is when i turn my parking lights on at night they will not turn on.  I also have no lighting in the gauge cluster either.  As soon as you arm or disarm the alarm you can see all the lights flash.  I noticed there is no voltage going to the dimmer switch.  Can anyone help me so i can drive my car at night.  It is a 94 honda accord ex.
Primo8998
Posted: March 15, 2004 at 2:49 PM / IP Logged
Ohh and the alarm used to operate normal.
kgerry
Platinum - Posts: 3,455
Posted: March 15, 2004 at 3:06 PM / IP Logged
replace the blown fuse feeding the parking light circuit....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Primo8998
Posted: March 15, 2004 at 3:20 PM / IP Logged
Checked all fuses.  All are fine.
kgerry
Posted: March 15, 2004 at 4:58 PM / IP Logged
if i were a betting man i'd bet you it's a blown fuse... many vehicles have more than one fuse panel...check in your owners manual for the specific location of the dash light fuse....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
raydawg357
Silver - Posts: 769
Posted: March 17, 2004 at 8:00 AM / IP Logged
Your car has 2 fuse boxes: drivers kick panel and under the hood.  Check all fuses by testing them.  Also your car has a male spade above the fuse box in the kick panel that works your flashing lights.  Some alarms can be programed for (-) or (+) flashing light s,  make sure yours is the correct polarity.
Do it right the first time
