Door panel
larrry29
Posted: March 16, 2004 at 6:17 AM / IP Logged
I have a 96 Geo Metro,
  I want to install power door locks, what is the easiest way to get the door panel off?
I have never taken door panels off and wasn’t sure if there is anything I should be careful with, what is the best procedure on getting the panel off?
        Thanks,
larrry29
Posted: March 16, 2004 at 6:44 AM / IP Logged
I have a 96 Geo Metro, want to install power door locks, what is the easiest way to get the door panel off?  I have never taken door panels off and wasn’t sure if there is anything I should be careful with, what is the best procedure on getting the panel off?
93accordSE
Copper - Posts: 203
Posted: March 16, 2004 at 8:53 AM / IP Logged
Make sure you have all the screws out and pop it off carefully, there are alot of hidden screws in door panels so if it isnt coming off look for a possible screw. Also you have to pop off the handle lever so don't pull on it too hard.
