Alternating light flash with relays
titanium
Posted: March 16, 2004 at 8:24 PM / IP Logged
I have a postitive light flash wire from my alarm I would like to get my park lights and my head lights to flash alternating and I'm not quite sure how to wire this with relays
its_radio_shop
Copper - Posts: 76
Posted: March 17, 2004 at 9:57 PM / IP Logged
Its possible to do but some questions would be...
Negative or Positive headlight system? Negative or Positive Park lights?  Are the two high beams isolated from each other (require a seperate output for each lamp)? I would probably look into buying a seperate headlight flasher and wiring the control wire to the output of the alarm. Much easier and cleaner.
auex
Platinum - Posts: 5,041
Posted: March 17, 2004 at 10:40 PM / IP Logged
It is easy and requires 2 relays.
Relay 1:
85 - +siren output from alarm
86 - ground
30 - constant +12V
87 - +output to relay 2
Relay 2:
85 - +light flash output from alarm
86 - ground
30 - +output from relay 1
87A - either parking lights or headlights
87 - the one not used from pin 87A
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
its_radio_shop
Copper - Posts: 76
Posted: March 17, 2004 at 11:37 PM / IP Logged
The setup auex shows will only work if you have positive switching headlights and park lights. Some vehicles will be negative in one or the other or both.  In most cases even with negative switching headlights you will still have positive switching park lights. Try to determine what you have before hooking anything up.
loco_k0pykatz
Posted: March 23, 2004 at 12:19 AM / IP Logged
How would you make 2 fog lights flash alternately?
Thanasi
Posted: March 27, 2004 at 2:14 PM / IP Logged
The same way you would with your parking lights or headlights using two relays.
Relay 1:
86 - ground
30 - constant +12V
Relay 2:
86 - ground
werox709
Posted: May 26, 2004 at 1:26 PM / IP Logged
ok thats one way but hopw to do it if i dont have a car alarm????
can any one help me with that???
"WErOx"
Friday, July 18, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
