Amp and Sub Wiring Question
bfog99
Copper - Posts: 212
Posted: March 18, 2004 at 11:40 PM / IP Logged
more or less. you amp is only 4 ohm stable in bridged mode. you will fry your amp if you try this. it might take a month or so, or it might be right away. i wouldn't try it if i were you.
Ketel22
Silver - Posts: 976
Posted: March 19, 2004 at 12:05 AM / IP Logged
about frying the amp, it may take a longer time than that, it took me almost a year to burn up my 4 channel sony with two R10's
Quad L Handyman services
cdn_moose
Member - Posts: 14
Posted: March 19, 2004 at 7:36 AM / IP Logged
So I will need to run each sub on its own channel, then how does it bump in stereo?  Do I only plug in one channel in the RCA from then head unit?
bfog99
Copper - Posts: 212
Posted: March 19, 2004 at 4:44 PM / IP Logged
you will still need to use both RCA inputs. you will take the L and R RCA outputs on the deck and run RCA wires to the amp and plug in the respective L and R on the amp. then you will hook up each sub to its own channel.
vs90
Posted: March 19, 2004 at 5:05 PM / IP Logged
also, some decks have a mono sub output.. my Sony CDX-M630 has a dedicated sub out put with two mono RCA jacks.. just run rca cables to each of the inputs on your amps if you are able
