problems with DEI keyless entry
mikew04
Copper - Posts: 52
Posted: March 27, 2004 at 11:51 PM / IP Logged
I bought a DEI keyless entry for my 94 toyota, and i wired up the locks, parking lights, horn, starter kill, domelight, LED, and valet switch. I used a relay for the domelight supervision, but it does not work. I temporarly connected it to an open channel to test the wiring, and it worked. I dont think the (-) 200mA output wire is sending a signal. Also, my LED has stopped working. How do I test these? I have a DMM.
Thanks alot
mikew04
Copper - Posts: 52
Posted: March 28, 2004 at 11:29 PM / IP Logged
Isnt there anyone who can tell me how to test the output wire(s)?
draasch
Gold - Posts: 2,172
Posted: March 28, 2004 at 11:34 PM / IP Logged
https://www.the12volt.com/relays/page4.asp#ien
just put your meter probe on each wire of the led
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Platinum - Posts: 12,488
Posted: March 29, 2004 at 8:49 AM / IP Logged
What kind of relay did you use and also how did you wire the relay ?
mikew04
Copper - Posts: 52
Posted: March 29, 2004 at 10:37 AM / IP Logged
30amp Bosch SPDT relay, ran a wire off the domelight wire in the kickpanel, wired that to terminal 87, 86 to +12v, 30 to ground, 85 to the unit
mikew04
Copper - Posts: 52
Posted: March 29, 2004 at 11:46 AM / IP Logged
BTW, if i ground 85, the dome lights come on... think its the keyless entry unit itself thats messed up?
thanks
Tuesday, February 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
