Avantguard 5, Chevy Silverado 02
badjetski
Posted: March 30, 2004 at 11:05 AM / IP Logged
Hey Guys,
Had a Avantgaurd 5 in this past weekend and I’m working on the only “Bug”.
Vehicle: 2002 Silverado HD
When I auto start the truck everything inside starts like it should, now if I immediately turn off the auto start the retained accessory power stays Hot for 5-8min. The stock sytem is waiting for the door to open before it turns off the retained accessory power.
If I auto-start then immediately turn off the auto-start via the remote the stereo (headlights, interior lights.ect) will stay ON for 5-8min. with the Avantgaurd 5 in armed mode.
Anyway to disable the stock retained accessory power, I would like to see everything turn off when I turn the truck off.
Thanks for your help.
badjetski
Posted: March 30, 2004 at 11:16 AM / IP Logged
Let's try that again,
Hey Guys
I had a Avantguard 5 put in this past weekend and I'm working on the only "Bug"
Vehicle:  2002 Silverado HD Pickup
When I auto start the truck everything inside starts like it should, now if I immediatley turn off the auto start the retained accessory power stays Hot for 5-8 min. The stock system is waiting for the door to open before it turns off the retained accessory power.
If I auot-start then immediately turn off the auto-start via the remote the stereo  (headlights, interior lights ect.) will stay on for 5-8 min with the Avantguard in armed mode.
Anyway to disable the stock retained accessory power, I would like to see everything turn off when I turn the key off.
Thanks guys
draasch
Gold - Posts: 2,172
Posted: March 30, 2004 at 5:02 PM / IP Logged
i have never done one before, but i think there is a post on here about that...you should need a relay....ill see what i can find on it...
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
sroth140
Silver - Posts: 513
Posted: March 31, 2004 at 9:48 AM / IP Logged
did you install a 555L to bypass passlock II?  thats the first thing.  second, are you using voltage sense, or a tach wire?  and third, after remote start shut down, the accy will stay on just as if you turned the key off.  they should turn off with power lock, but i cant say that works for sure.
MECP certified installer
