Hyundai Elantra 2002 Australia
badwolf
Posted: April 06, 2004 at 12:57 AM / IP Logged
Hi,
I have checked the other posts and am confused as to how to connect the keyless door locks to my alarm.
There is 2 black wires from the alarm with negitive pulse ..unlock and lock...by reading other post i found the control unit behind ashtray in middle of dash.
My problem is..... do I just find the wires at this module..... and join with the 2 wires from the alarm on to each colour (unlock /lock).
Also will the colour code for the Elantra be the same for Australia as in the USA model?
I have been baking in the hot sun for a week trying to sort out theses 2 wires, please help.
Thank you
Tony
Platinum - Posts: 12,488
Posted: April 06, 2004 at 1:01 AM / IP Logged
blk/org or blue *1  |F  |white 22 pin plug in DKP
http://www.velocitymotorsport.com/images/install_notes/148.jpg
Use the above information to wire into the Elantra's type-F one wire system.
badwolf
Posted: April 07, 2004 at 9:06 PM / IP Logged
Thank you Jeff for the information.....will give it a go...fingers X
Tony
badwolf
Posted: April 08, 2004 at 12:22 AM / IP Logged
Hi again,
the blue wire has +12 volts and the ORANGE / blck 0 volts
i think this central locking on the elantra is a two wire system  (negitive???) it has a rod from the keylock  which triggers the door locks...
the alarm i am using is a RHINO  model (RA) made in oz
the instructions say to use 2 relays it vehicle is positive pulse power lock system........ or none if negitive pulse system...
all the wiring is black and  is so hard to keep track of the wires.
this is sooo confusing.....please need more help
thanks
Tony
badwolf
Posted: April 08, 2004 at 2:26 AM / IP Logged
bump!
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
