tweeters popping
hammondc
Copper - Posts: 112
Posted: April 06, 2004 at 3:45 PM / IP Logged
JL VR series separates powered by eclips 3640 4 channel amp (4X60). Tweeters popping at medium high volume. Why is this? what can I do to stop it?
mobile E
Copper - Posts: 217
Posted: April 06, 2004 at 3:47 PM / IP Logged
i just got some vr seperates... havent installed the crossovers and there popping.. so thats proboably why...
everything stolen :(
Workin on a new system :)
tweeters popping -- posted image.
Peace in the middle east
hammondc
Copper - Posts: 112
Posted: April 06, 2004 at 3:59 PM / IP Logged
i had them installed at a sound shop so, if the xovers are not installed. I will be in jail soon.
hammondc
Copper - Posts: 112
Posted: April 06, 2004 at 5:11 PM / IP Logged
nope. the x-overs are in there. anything else? They are supposed to have a protection circuit to keep from blowing them.  Ideas??
DYohn
Platinum - Posts: 10,741
Posted: April 06, 2004 at 5:54 PM / IP Logged
Amplifier grounding and gain setting.  Also quality of signal to the amp (RCS cables, etc.) and quality of the speaker wire to the tweeters.  Are the woofers "popping" too or just the tweets?
Teamrf
Gold - Posts: 1,031
Posted: April 06, 2004 at 6:38 PM / IP Logged
Yea like Dyohn said you may want to check that ground. I've seen a lot of things go wrong because of a bad ground.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
hammondc
Copper - Posts: 112
Posted: April 06, 2004 at 6:47 PM / IP Logged
they only pop at loud volume. speaker wire is good. also, theRCA are ZeroNoise 3.5's by whoever makes them. think it would stop if I drop the gain on the amp?
DYohn
Posted: April 06, 2004 at 8:33 PM / IP Logged
Chcek to make sure the ground is good and solid and is an unpainted bare metal connection to the chassis of your car.  The gain should be set to match the input from the head unit.  Was it set up properly, or just plugged in and turned on?
Tweeters (or other speakers) making a "popping" sound can also be from overdriving them at too low a frequency.  This will blow them in short order.
hammondc
Copper - Posts: 112
Posted: April 07, 2004 at 8:23 AM / IP Logged
I will check the ground. They have crossovers in place, so it is not a frequency issue. If that is all the power / volume that these speakers can take, I will never go JL again. I know it is good clean power. I never have been a fan of JL and this is my first experience with them. Not exactley thrilled.
DYohn
Posted: April 07, 2004 at 10:00 AM / IP Logged
And also make sure the amplifier gain is set properly.
