Speaker Adapters
four door
Member - Posts: 6
Posted: April 09, 2004 at 1:30 AM / IP Logged
Doing an amature install and have no idea where to start looking for an item. The cutouts for the speakers are 4.5" and the speakers are 4" which leaves a small gap. I was wondering if a company makes a mounting plate that would add some width to the edge of the speaker frame. Any assistance would be greatly appreciated. Four Door.
four door
speedwayaudio1
Silver - Posts: 879
Posted: April 09, 2004 at 1:59 AM / IP Logged
make one your self. use 1/4 plywood. cut out the 4.5 hole drill mounting holes in it. then cut out the 4" hole in the center. drill your speaker mounting holes. easy. If you have a rotozip its real easy. I like the rotozip better than a router. make one out of thin card board first, and use it as a template.
Big Dave
aggie altima
Silver - Posts: 298
Posted: April 09, 2004 at 6:26 AM / IP Logged
not sure what car it is... seeing that you are in Albania. Check www.crutchfield.com, and see if they have your make and model. If they do, they most likely have your adaptor. I got some adaptors from them for my 2000 Nissan Altima 6 3/4" holes which will fit a 6 1/2" speaker.
Jon
Don't like rockford subs? Then don't look at my car =)
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
