toyota sequoia 03 windows wires
rwidget
Posted: April 13, 2004 at 6:49 PM / IP Logged
can anyone help me?
im trying to install 2 ( 2 window mods) for front and rear windows in an 03 sequoia with alarm activation to roll up windows and found that the drivers side control does not have motor wires connected to it.  instead each door has a releay on the switch itself.
i probed the main control and could not find any wires that would respond to each switch being activated.
i took apart the main control and found ic's inside, so i think it could be type of control for each individual door.
can someone help with color of wires and polarity.
widget
123456
JWorm
Platinum - Posts: 2,208
Posted: April 13, 2004 at 7:55 PM / IP Logged
The info I have shows the Up wire being Red, and the Down wire being Green located at the switch in each door. So it looks like you'll have to run wires into each door.
rwidget
Posted: April 14, 2004 at 12:05 PM / IP Logged
thats what i thought, but wasent sure.
1. will any window mod work on this car?
 2. is there anything special i have to do
the car outputs 20 volt dc and im using 2 mas window mods.
123456
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
