Power Windows Problem Intrepid
tadziu2001
Member - Posts: 8
Posted: April 14, 2004 at 10:08 PM / IP Logged
Hello!
I have been trying to hook up power window rollup module in my intrepid. I have all the wires hooked up except the activation and the accesory. THe one that i am most concerned about is the activation. I want the windows to go up on alarm arm. I dont know where to hook it up to. I have a starter kill but the two wires that ground, they ground when i turn off the key. I dont know how to hook it up so when i turn the alarm on the windows go up. Thank you!!!
Platinum - Posts: 12,488
Posted: April 14, 2004 at 10:27 PM / IP Logged
The starter kill wire is the wire that your looking for. Most systems will (-) ground when armed, but this may also be a programmable option.
CutDog504
Silver - Posts: 643
Posted: April 15, 2004 at 12:33 AM / IP Logged
You'll wanna use the ground when armed wire (usually orange) and make sure you diode islolate it from the starter kill relay, otherwise the windows will roll up every time you turn off the ignition.
Saturday, January 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
