How can I test if my HU has a bad ground?
bfeeny
Member - Posts: 48
Posted: April 16, 2004 at 9:21 AM / IP Logged
What are the symptoms of an HU having a bad ground, and whats a good way to test? I installed my Eclipse CD8443 with a amplified antenna adapter, and i feel i have worse FM reception than I did with the stock radio..........someone said that its possibly trying to ground thru my antenna.
Just trying to figure out how I could check this.
Brian
sonicsound
Copper - Posts: 100
Posted: April 16, 2004 at 10:02 AM / IP Logged
You could do a couple of things... try taking your ground wire from your HU and ground it to the chasis of the car, not a piece of metal behind the HU or on the HU.  The other side to this is that sometimes those amplified antennas can make things worse, and I know for sure that amplified antennas usually boost the AM more than the FM stations.  Or at least that's what I have notice 7 out of 8 cars I installed them on at Circuit City.  Hope that helps...
Sonic
Pioneer AVH-P4000DVD
Zapco 360.4
Zapco 500.1
Zapco SP-4SL Processor
Two JL 10 W3v3d2
Alumapro 15 Farad Cap
kgerry
Platinum - Posts: 3,455
Posted: April 16, 2004 at 1:06 PM / IP Logged
whats it in? a VW?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
forbidden
Platinum - Posts: 5,352
Posted: April 16, 2004 at 1:49 PM / IP Logged
Or some of the newer GM or Buick vehicles?
bfeeny
Member - Posts: 48
Posted: April 16, 2004 at 2:16 PM / IP Logged
Yes its in a VW, why do you ask? 2003 VW GTI.
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
