pioneer navigation problem
eemore
Posted: April 19, 2004 at 8:07 PM / IP Logged
I have just installed the  Pioneer sys610T.  The problem is I get power to the head unit (it ejects CD, powers up), but I can't get a video signal from it.  I don't know if it works.
The touch screen monitor works fine a plugged it into a dvd player and it works fine.
Does anyone know what's going on?
eemore
Posted: April 21, 2004 at 5:16 PM / IP Logged
Ok here's the story:
Called Pioneer today and described what's going on.  They stated that it sounds like a wiring problem and I should take it to a installation center to make sure it is wired correctly.  How else can you wire it?  I asked them, if I apply power to the constant and acc wire while grounding the black wire I should get something but I don't...NOTHING.
What will the installation center do that I haven't?
I've checked for 12+ on constant, 12+ when the acc in turned,it grounded, illumination wire is getting 4.5 volts, reverse is 12+ in reverse, park brake switch is grounded, vss not connected.
What more can be checked?
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
