Hood pin
Pooreclipse
Copper - Posts: 75
Posted: April 22, 2004 at 3:08 PM / IP Logged
Can you tell me where to get a pin or switch that can detect the hood opening.  Can I get somehting at radio shack?  Because if I go to the stereo / alarm  shops it would be like $20 I bet.   Well a door actuator cost $28.!!!
profuse007
Gold - Posts: 2,015
Posted: April 22, 2004 at 3:18 PM / IP Logged
what kind of car is it? some cars out there have stock pins that you can just tap into.
Houston,TX
Pooreclipse
Copper - Posts: 75
Posted: April 22, 2004 at 4:58 PM / IP Logged
1995 Nissan 240 SX.   Thanks
jfk51502003
Copper - Posts: 221
Posted: April 22, 2004 at 5:08 PM / IP Logged
THIS SHOULD HELP......!!!!!!!
12volts white   +  ignition harness
Starter BLACK / YELLOW   +  ignition harness
Second Starter BLACK/ white   +  ignition harness
Ignition BLACK/ red   +  ignition harness
Second Ignition
Third Ignition
Accessory white   +  ignition harness
Notes: When doing remote start, this wire must be isolated from the keyswitch with the accessory relay. See direct fax document #1077.
Second Accessory
Keysense
Power Lock lt. GREEN / WHITE   -  anti-theft module
Notes: The anti-theft module is located just above hood release cable in the drivers kick panel. Other wires at the anti-theft module are: 12V-WHITE/ red, ignition-green, ground-black, left door pin-gray/red, right door pin-blue, panic(horn and high beam)-YELLOW /GREEN.
Power Unlock brown   -  anti-theft module
Lock Motor
Unlock Motor
Parking Lights+ RED / blue    ignition harness
Notes: There are two (2) RED / blue wires in the ignition harness, one is for parking lights and the other is for the right headlight.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger RED / white   -  harness in driver kick
Dome Supervision
Trunk/Hatch Pin red   -  anti-theft module
Notes: If not equipped with an anti-theft module, the red wire is located in a harness at the left trunk hinge.
Hood Pin yellow/black   -  anti-theft module
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm lt. GREEN/ red   -  anti-theft module
Factory Alarm Disarm GREEN/ YELLOW   -  anti-theft module
Disarm No Unlock
Tachometer yellow/red   ac ECM in passenger kick
Wait to start
Brake Wire RED / green   +  brake switch
Parking Brake
Horn Trigger YELLOW /GREEN   -  anti-theft module
Memory Seat 1
Memory Seat 2
Memory Seat 3
Hood pin -- posted image.
Immobilizer Bypass Module:Required: NoType: N/APart #: N/A
Notes: N/A
YOU...
profuse007
Gold - Posts: 2,015
Posted: April 22, 2004 at 5:17 PM / IP Logged
damn, whats up w/ the long post?
Houston,TX
marbman40
Posted: May 12, 2004 at 11:52 AM / IP Logged
go to www.partsexpress.com     door actuators 3.98  pins not sure
markcars
Silver - Posts: 662
Posted: May 12, 2004 at 3:03 PM / IP Logged
If you plan on getting a remote-start, a hood-pin switch comes with it, inclusive, for no extra charge.
