mannix/2000 accord door sensor/dome light
sgtjnelson
Posted: April 25, 2004 at 9:29 PM / IP Logged
i have a 2000 v6 accord 4 dr lx. recently purchased mannix remote start car alarm. im having trouble with completing the circuit correctly for the door sensors and dome light. as of now when alarm is armed the door on the lcd pager flashes and the siren sounds shortly after. the alarm seems to not recognize that the door is secured. also the srs light on instrument panel stays lit. can anyone help me please...all replies are welcome...thank you in advance
raydawg357
Silver - Posts: 769
Posted: April 26, 2004 at 8:05 AM / IP Logged
Your door pin is in the passenger side fuse box:  BLACK/ white (-)
HONDA, ACCORD, 2000, Door Trigger
In a green 4 pin connector.
If you already have this wire tapped, check your door pins and make sure they are all good.  Also, check to make sure your hood pin switch is adjusted correctly.
Do it right the first time
Platinum - Posts: 12,488
Posted: April 26, 2004 at 9:44 AM / IP Logged
SRS light is because of an ignition wire not being powered up properly when remote started. You will need to reset this error from the dealership or manually. Make sure that you used the correct door trigger input wire on the alarm harness. Most systems come with 2 door input wires, one for (+) type systems and one for (-) type systems, in this case you should have used the (-) input wire for the Accord.
sgtjnelson
Posted: April 26, 2004 at 7:48 PM / IP Logged
 do you think that the srs light is on because i took out the drivers seat and had to disconnect a connector that was part of the srs to do that.
also with this BLACK/ white wire ...do i cut in half from fuse box and run one end to 30 on the relay and the other to 87a...if so which end goes to which
i appreciate your guys help...it was much needed...thank you
