Quickstop option for remote start
thedishking
Posted: April 27, 2004 at 9:26 AM / IP Logged
Hello all.  I have a designtech remote start that has a "quckstop" feature.  After the vehicle is in park, you can toggle the valet switch a couple of times and take the key out, but the vehicle stays running for 10 minutes or so.  Basicly same as using remote start, but never engages starter moter.
I am going to be installing a viper 791xv because I want the added features like 2 way remote and better range.  Is there a way or an option for the dei products to do this?    Saves alot of unneeded wear on the starter motor.
Thanks!
kgerry
Platinum - Posts: 3,455
Posted: April 27, 2004 at 4:56 PM / IP Logged
that feature is built into all DEI products, it's called " valet takeover" all you do is activate the unit ( press the RS button on the remote with the vehicle running ) then remove the key and it will run for it's programmed run time... simple, yes?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Wednesday, August 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
