cold solder on window rollup
sufferrar
Copper - Posts: 190
Posted: April 29, 2004 at 9:07 AM / IP Logged
After about a month or 2 my fromt windows stick . i constantly have to keep pressing the up or down to get the window to move ...with one press in only goes about an inch....i have discovered that cold solder develops on the inside of the window roll up module (dei i think it is the 530t)on chips... i reheat them with new solder and will solve my probs...
it usually happen on the driver window the most because of the constant use it gets...
my question is: does the high current to drive the motors flow through this box and the traces on the circuit board of the 530t cannot handle this amount of current?
"I'm So Loud It Hertz"
crudeau
Copper - Posts: 150
Posted: April 29, 2004 at 10:59 AM / IP Logged
I had to upgrade my 530T for my mustang.  THe factory dip switches didn't provide enough juice for my windows.  So I soldered in some new resistors.  I will see if I can find the article on the DEI site for you.  Sounds like exactly what you need to also.
I found it let me figure out how to attach it now.
crudeau
Copper - Posts: 150
Posted: April 29, 2004 at 11:00 AM / IP Logged
I have the PDF file from DEI but I am not sure how I can post it up.  It's four pages so I can't just copy and paste it.
Let me know what to do and hit me up on aol IM.  crrudeau is my screenname.
tcool
Copper - Posts: 100
Posted: June 05, 2004 at 4:00 PM / IP Logged
I have a 98 Navigator that I just installed a new 530t in. I am running 10 gauge wire to it, but I can never get full travel. I set all the dip switches to the least resistance (max power), and verified that I have a new 530t with surface mount resistors soldered on the circuit board. I assume these cannot be changed. Do I have any options to get more power out of this thing, or should I look for an old one and try to put new resistors in it. I have tried the omega, crimestopper and several generic window roll-up modules, and none work well. I really like the one touch automation system. HELP!
bzzzzttttt
auex
Platinum - Posts: 5,041
Posted: June 06, 2004 at 3:19 AM / IP Logged
The resistor issue has already been addressed, like 4 years ago. You should no longer have to solder in a resistor, there should be new dipswitch settings. By the way the resistor setting is not how much power goes through but when the module will stop, so turning the resistance down is actually making your problem worse. Which window are you having problems with? Where is the module located, in door or under dash?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
tcool
Copper - Posts: 100
Posted: June 06, 2004 at 2:34 PM / IP Logged
Thanks auex, actually I have tried every setting and none of them work. I mounted the unit in the door and ran 10ga. power wire. The ground is good, I did double check by running directly to the battery with the same results. I've tried at least 3 window modules with the same results, I've lubed the window mechanism. I think my window mechanism is too stiff. I think I'm going to go with relays and a timer.
bzzzzttttt
auex
Posted: June 06, 2004 at 4:21 PM / IP Logged
No, the ground is not good. Never mount the unit in the door, the unit is NOT waterproof and the ground is crap in the door. What good is 10 Gauge power wire when you ground the wire is screwed to the door. Run the ground into the vehicle and ground it there, then try it.
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
