double din in gm?
dbiggss
Posted: May 03, 2004 at 6:34 PM / IP Logged
i have a premium delco hu w/cd and eq in a 96' grand prix gtp - can i fit a double din head unit as a replacement?
bfletcher
Member - Posts: 29
Posted: May 03, 2004 at 7:12 PM / IP Logged
I believe that is a din and 1/2 not a double din.
Chad7n7
Silver - Posts: 408
Posted: May 04, 2004 at 12:01 AM / IP Logged
bfletcher is indeed correct, it is a 1.5 din opening. So it isn't possible to install a 2 din unit without some major surgery.
dbiggss
Posted: May 05, 2004 at 2:42 AM / IP Logged
damn - found a nice double din at a good price that i wanted. oh well, glad i checked on it first - and thanks for the info fellas. by the way - im thinking about keeping the stock premium sound system and upgrading it - however, the rear 6x9's have 2 leads one for the woofer(4ohm) and one for the tweeter(10ohm). therefore my question is how could i convert the signal through an loc and not lose all the higher frequencies that i want to get through the 6x9's as well. i was thinking about just converting the signal from the front speakers(i think their full range) and then splitting them off  to the loc and running all the speakers through an amp. do you think that itll work.
kgerry
Platinum - Posts: 3,455
Posted: May 05, 2004 at 10:00 AM / IP Logged
as long as the front speaker signal is Full Range then yes it will work
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
