I blew them uP on da’ first day - !
engage_vx
Member - Posts: 24
Posted: May 09, 2004 at 9:05 PM / IP Logged
zup fam  -
ok, the install went well (though I know the subs are not wired in 1ohm) I mean, according to the diagram you djorn sent me, when the DVC subs are wired for 1 ohm load, there's only suppose to be one neg & one pos wire coming oput of the sub box right fellas - ? Please help me proff this guy wrong - ! Also, the component speakers are not strong enough to keep up with a kicker 04kx650.4 which RMS per channel is 120watts into 4 ohms. The speakers I blew are the kicker K60 65 watts RMS 130 maxx - I think the amp is too strong cause when I put the vol up I hear distortion though the gains are set accordingly. Can someone recommend a pair of 6.5 speakers that can handle 120 rms minimum - ?
thanks fam -
engage -
ahh - ?
what did you say - ?
DYohn
Moderator - Posts: 10,741
Posted: May 09, 2004 at 11:01 PM / IP Logged
Are you talking about me, because I don't recall sending you any diagrams...
In any case, what are you talking about?  Your blew your mains?  And if you "put the vol up I hear distortion though the gains are set accordingly" then I would have to argue that either your gains are NOT set according to any good practice, or your head unit clips.
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: May 09, 2004 at 11:57 PM / IP Logged
I agree with DYohn.  Because if he is wrong, then you have even more of a serious problem than blown speakers.  With 125 watts to any component speakers, they should get loud enough to do some serious harm to your hearing, way before damaging themselves.
Steven Kephart
Adire Audio
engage_vx
Member - Posts: 24
Posted: May 10, 2004 at 9:26 AM / IP Logged
fam -
can someone suggest a pair of 6.5's with a min of 120 rms @ 4omhs - ? the kx650.4 can shoot 170x4 rms @ 2omhs. any suggestions - ?
ahh - ?
DYohn
Posted: May 10, 2004 at 2:47 PM / IP Logged
The reason you blew your speakers is they are rated for 65 watts and you powered them with 120 watts.  Blown speaker is a very likely outcome of that pairing.  Bad amp choice for those speakers, or bad speaker choice for that amp.
engage_vx
Member - Posts: 24
Posted: May 10, 2004 at 3:12 PM / IP Logged
DYohn -
So who actually makes 6.5's that can handle that kind of power - ?
ahh - ?
DYohn
Posted: May 10, 2004 at 4:06 PM / IP Logged
Check out your other thread.  Not many 6.5" full range speakers can actually handle 120+ watts RMS, although several claim they can.  In the component world you have more choices.
Sunday, August 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
