question about wiring
Elderm1
Posted: May 12, 2004 at 2:42 PM / IP Logged
1st post
Im installing a 1F cap and 2 amps and i want to be able to turn off each amp with a switch, question 1 can i just put a switch on the rem or do i put it on the power? ( I think the rem switch will work but im just a noob at this stuff) question 2 do i need a circut breaker on the cap to turn it off when im driving and the amp if off ???
What would the point be without stuff!
DYohn
Moderator - Posts: 10,741
Posted: May 12, 2004 at 3:00 PM / IP Logged
No need to switch a cap.  Once they are charged they do not place any load on your system if the amps are off.  Install your amp-on switch in line with the REM lead, not the power.
Elderm1
Posted: May 12, 2004 at 3:04 PM / IP Logged
THanks for the info
