Amp wiring questions
nottelling
Member - Posts: 13
Posted: May 12, 2004 at 3:09 PM / IP Logged
I have 2 rockford rfp4810's and a sony 444 watt amp..im not sure about the other specs on the amp, I'm wondering if i'm gettin enough power to my subs and if this amp is big enough then how to wire it correctly.
DYohn
Moderator - Posts: 10,741
Posted: May 12, 2004 at 3:37 PM / IP Logged
What's the amplifier model number?
nottelling
Member - Posts: 13
Posted: May 12, 2004 at 3:48 PM / IP Logged
i think the model # is xm-444.  Someone told me that the ohm ratings don't match the subs, but i can't find the amps documentation anywhere..lemme know if you need more info..thanks for the quick responce
DYohn
Posted: May 12, 2004 at 4:11 PM / IP Logged
That amp is rated at 35 watts X 4 at 4 ohms or 80 watts X 2 when bridged into 4 ohms.  The only way you could use this amp with your subs is to connect one sub to each set of bridged amplifier channels.  If your subs are the 4-ohm version, they will receive 80 watts RMS, and if they are the 8-ohm versions they will receive about 40 watts RMS.  This amp is not a real good choice for these or any other subs.
nottelling
Member - Posts: 13
Posted: May 12, 2004 at 4:12 PM / IP Logged
I didn't think so, but its what I had lying around..what amp would u recommend within $200.00 range
nottelling
Member - Posts: 13
Posted: May 12, 2004 at 4:17 PM / IP Logged
these are the 8 ohm subs too btw
DYohn
Posted: May 12, 2004 at 4:25 PM / IP Logged
A few decent mono sub amps that can be had in the $200 range are the US Acoustics USB-600D, Alpine MRP-M350, Directed 250D, Lightning B350.1.
nottelling
Member - Posts: 13
Posted: May 12, 2004 at 4:43 PM / IP Logged
do you know of any amps that'll push 200 watts to each sub?  Also (last question)  What kind of enclusure is best for these?  I have a bandpass and a ported enclosure lying around, but i'm unsure of their specs..thanks again for your help
casedeez
Copper - Posts: 160
Posted: May 12, 2004 at 4:52 PM / IP Logged
I wouldnt recomend buying any of sonys amplifiers. Sorry to all you sony fans, persoannly the only thing I have ever had that was sony and was decent was a head unit and that was about 5 years ago.
As far as amps go your sub is single voice coil and 8 ohms you can get it down to 4 ohms. The amps im running now are kicker zr360's. They are old but theyre tanks. In my opinion. You can find them on ebay for under 200. You would get 360 watts with a 4 ohm load. Thats my two cents.
casedeez
Copper - Posts: 160
Posted: May 12, 2004 at 4:53 PM / IP Logged
As far as enclosure you should look at what RF says about that. If you decide to use one of those boxes laying around then make sure they are the right size, both in volume and in ports.
Tuesday, September 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
