2004 F150 Questions
Memphisman
Copper - Posts: 161
Posted: May 14, 2004 at 7:23 PM / IP Logged
I have a couple of questions about installing a RS in a 2004 F150
1)Is there a 2nd Ignition? If so, what color (I have diagrams from 2 sources. One says it does one says it doesn't)?
2)The sources I have say that the lock and unlock wires are (-) if equipped with RKE. I found the wires and I only get .9V from them. Is this correct or am I testing the wrong wires (I'm testing them in the driver door boot)?
auex
Platinum - Posts: 5,041
Posted: May 14, 2004 at 7:43 PM / IP Logged
1. I only see one ign on my diagrams, dk. blue/lt. green.
2. When using a multimeter, have the com lead (usually the black lead) going to ground. Then test the lock wires. At rest they will show +12V. When the switch is pushed they will show close to 0V. Wire colors are pink / YELLOW for lock and pink/lt. green for unlock -trigger, both can be found in the kick panel.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
