L5 kickers
openseason
Member - Posts: 9
Posted: May 18, 2004 at 4:18 PM / IP Logged
i have a pioneer  deh-p8500 mp head unit running to a mtx thunder 4250d amp powering 2 solo barik l5 10" subs. does anyone have any suggestions on the best way to wire the subs ?[subs in sealed box}
openseason
openseason
Member - Posts: 9
Posted: May 18, 2004 at 4:36 PM / IP Logged
oh yah should i enable non fading output on head unit
openseason
customsuburb
Gold - Posts: 1,813
Posted: May 18, 2004 at 4:56 PM / IP Logged
What is the impedance of your subs and are they dual voice coil? You should use the non-fading outputs if you want to connect them to a sub amp.
openseason
Member - Posts: 9
Posted: May 18, 2004 at 5:34 PM / IP Logged
here are specs of subs
  • copolymer cone
  • Santoprene rubber surround
  • dual 4-ohm voice coils for wiring flexibility
  • frequency response 24-100 Hz
  • power range 50-450 watts RMS (225 watts per coil)
  • peak power handling 900 watts
  • sensitivity 86 dB SPL
  • top-mount depth 5-5/8"
  • sealed box volume 0.66-1.0 cubic feet
  • ported box volume 1.25-2.25 cubic feet
  • Recommended Box Type: none
  • 1-year warranty
Priced per speaker
openseason
customsuburb
Gold - Posts: 1,813
Posted: May 18, 2004 at 6:08 PM / IP Logged
OK this amp is not a good match for these subs. You can either wire these subs to present a 1 or 4 ohm load on your amp and your amp is not 1 ohm stable so you will be underpowering them. I would consider buying the 801D instead. You will have to wire each woofers coils in parallel and then wire them both to the amp in series:
L5 kickers -- posted image.
openseason
Member - Posts: 9
Posted: May 18, 2004 at 6:29 PM / IP Logged
are those instructions for my amp or the one you recomend..and also do i wire them to the left or right channel.  thanks alot for your help
openseason
customsuburb
Gold - Posts: 1,813
Posted: May 18, 2004 at 6:43 PM / IP Logged
Those instructions were for the amp you own right now (4250d). I made a mistake in the above post suggesting the 801D because its not 1 ohm stable either. I would either use a higher power 2 channel amp (like the Rockford Fosgate Punch P8002) , and wire the subs for 4 ohms, and bridge the amp or buy a nice 1 ohm stable mono amp, like the JBL BP 600.1 or the Hifonics Nemesis NX750D maybe. I would go with the second option.
openseason
Member - Posts: 9
Posted: May 18, 2004 at 8:12 PM / IP Logged
sorry there 2 ohm speakers
openseason
openseason
Member - Posts: 9
Posted: May 18, 2004 at 9:30 PM / IP Logged
 can someone tell me how to wire the duel 2 ohm voice coils for best performance with my amp mtx thunder 4250d amp ? thanx for any help....and do i use both right and left hook ups on the amp or just one set
openseason
stevdart
Platinum - Posts: 5,816
Posted: May 18, 2004 at 10:37 PM / IP Logged
     They changed ohms pretty fast there.  Thank you customsuburb for the work you did...
     Wire each sub in series for 4 ohms.  Parallel the two subs to make one 2 ohm load.  Connect neg. to one neg. post on the amp;  connect pos onto one pos on the amp.  The amp is single channel, which means you have to use both sides.
Wednesday, February 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
