Viper 550HF problem
kcalvert_25
Member - Posts: 14
Posted: May 23, 2004 at 3:44 PM / IP Logged
Iwas wondering if anyone has had this same problem, when i arm and disarm the siren does not chirp. everything else works, park lights, led, relays clicking. the siren will work if i hold the remote button down to go into panic mode, and i also checked to make sure it was out of valet mode. any ideas???
Keith
profuse007
Gold - Posts: 2,015
Posted: May 23, 2004 at 5:08 PM / IP Logged
check to see if youve accidentally turn off the arm/disarm chirp
Houston,TX
kcalvert_25
Member - Posts: 14
Posted: May 23, 2004 at 5:24 PM / IP Logged
not sure how to do that, ill look in the manual. i havent hooked it up in a car yet. bought it off ebay and just bench tested it!!
thanks
13 volts
Member - Posts: 37
Posted: May 24, 2004 at 12:12 AM / IP Logged
If the LED is on all the time, except if the car is running, you may have it in VALET MODE. This happens alot to my customers. Keep a door open and press the upper left button once then upper right button once and then upper left button once. LED should turn off. Owners manual!
kcalvert_25
Member - Posts: 14
Posted: May 24, 2004 at 10:53 PM / IP Logged
no its not in valet mode, i havent installed it in a car yet, i got it off ebay, and was trying to test it the best i could with a 12 volt power supply. anybody know where i can get one of those dei alarm test hook ups, seen one on ebay once but didnt win the auction!!
thanks
profuse007
Gold - Posts: 2,015
Posted: May 24, 2004 at 11:48 PM / IP Logged
i bet the chirp is being turn off, have you try to program it to ON?
Houston,TX
madmods
Member - Posts: 30
Posted: May 25, 2004 at 12:13 AM / IP Logged
profuse007 is absolutely right. Chirps are proabally  turned off. look at the install manual on how to do this. If you dont have one, both install and owners manuals are on dei website. Free download on pdf file.
kcalvert_25
Member - Posts: 14
Posted: May 25, 2004 at 5:32 PM / IP Logged
thanks guys!!!!
