1999 Chrysler Intrepid Remote Start Install
GeoP
Posted: April 14, 2002 at 12:11 PM / IP Logged
I am having trouble understanding the interface to:
Power Door Locks (620 and 2700 ohm resistors) and the Parking Light Flash(park lights energized by a fac relay and 44-49ohm resistance in the headlight/BCM circuit). Do I have to hook-up with resistors and relays or can I take the negative output pulse directly to the factory relay(s) ground side of coil?
Platinum - Posts: 12,488
Posted: April 14, 2002 at 9:25 PM / IP Logged
You will have to hook up both the relays and the resistors to make the keyless entry work properly:
Doorlock diagram: http://www.bulldogsecurity.com/wires/images/chrysler1wirecars.htm
Parking Light : http://www.bulldogsecurity.com/wires/images/dodgeintreplight.htm
If you need any more help, just post or email.
