2004 Toyota Corolla LE alarm/RS
shadowinfector
Copper - Posts: 199
Posted: May 29, 2004 at 12:11 AM / IP Logged
I am about install an alarm/rs to my friend's 2004 toyota corolla le. I need a wiring diagram for it . Please thanks in advance
jfk51502003
Copper - Posts: 221
Posted: May 29, 2004 at 9:18 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / COROLLA / 2004 / Remote Start
[PRINT THIS PAGE]
12voltswhite (25A) & black (15A) + ignition harness
Starterred + ignition harness
Second StarterN/A
IgnitionBLACK/ white + ignition harness
Second IgnitionBLACK / YELLOW + ignition harness
Third IgnitionN/A
Accessoryblue/red + ignition harness
Second AccessoryN/A
Keysenseblue/black - ignition harness
Notes: Using the status output to trigger this wire during remote start will disarm the factory alarm without unlocking the doors.
Power Lockgreen - driver kick, blue 12 pin plug
Notes: Meter these wires while turning the key in the driver door key cylinder.
Power Unlockblue / YELLOW (double pulse) - driver kick, blue 12 pin plug
Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue/black (-) in the passenger kick in a blue 12 pin plug.
Lock Motorblue 5widriver kick, blue 12 pin plug
Unlock Motorred 5widriver kick, blue 12 pin plug
Parking Lights+green + driver kick, harness to rear
Parking Lights-GREEN / WHITE - headlight switch
Hazardsyellow/black - flasher relay left of fuse box
Turn Signal(L)GREEN/ black + flasher relay left of fuse box
Turn Signal(R)GREEN/ YELLOW + flasher relay left of fuse box
Reverse LightRED / black + front of fuse box, 10 pin plug
Door TriggerRED / white - interior light switch on dash
Dome Supervisioncomes on with unlock
Trunk/Hatch PinRED / white - light in trunk
Hood PinN/A
Trunk/Hatch ReleaseN/A
Power Sliding DoorN/A
Factory Alarm Armarms with lock
Factory Alarm Disarmdisarms with unlock
Disarm No Unlockuse key sense wire
Tachometerblack ac pin 5, conn. E6 at ECM
Notes: The ECM (Engine Control Module) is behind the glove box. Connector E6 is the plug on the right.
Wait to startN/A
Brake WireGREEN / WHITE + brake pedal switch
Parking BrakeRED / black - parking brake switch
Horn TriggerGREEN/ YELLOW - steering column
Memory Seat 1N/A
Memory Seat 2N/A
Memory Seat 3N/A
2004 Toyota Corolla LE alarm/RS -- posted image.
Immobilizer Bypass Module:Required: NoType: N/APart #: N/A
Notes: N/A
shadowinfector
Copper - Posts: 199
Posted: May 30, 2004 at 9:27 AM / IP Logged
Thanx
jfk51502003
Copper - Posts: 221
Posted: May 30, 2004 at 10:25 AM / IP Logged
anytime...!
shadowinfector
Copper - Posts: 199
Posted: June 06, 2004 at 11:37 PM / IP Logged
I would like to know if there is any special instructions i would need while installing this like diodes,relays,etc.....j/a.....thanx
dfiddy
Copper - Posts: 162
Posted: June 07, 2004 at 11:56 PM / IP Logged
child locks, if power locks...should be negative trigger if memory serves me correctly. You must also do a 2nd pulse unlock to do so if you have child locks which more than likely do. If you do not know how to test holla back. =)
shadowinfector
Copper - Posts: 199
Posted: June 10, 2004 at 11:43 AM / IP Logged
so i would need to use diodes for the locks/??
jfk51502003
Copper - Posts: 221
Posted: June 10, 2004 at 1:05 PM / IP Logged
ummmm...if i remember correctly...you need to just diode isolate the child safety...line towards wire...but any other info...?
shadowinfector
Copper - Posts: 199
Posted: June 10, 2004 at 4:40 PM / IP Logged
which wire is the child safety>??
profuse007
Gold - Posts: 2,015
Posted: June 10, 2004 at 4:51 PM / IP Logged
heres a link for more info
Houston,TX
