wire a push button start
harlyneisenmann
Member - Posts: 43
Posted: May 29, 2004 at 8:20 PM / IP Logged
i need help on wiring my push button start, i want to wire everything else to toggle switches, the only thing i want to use my ignition for is to lock the steering wheel, can anyone help me let me know what wires i need to hook ip and how manty toggle switches i need to use please help.
        harlyn eisenmann
auex
Platinum - Posts: 5,041
Posted: May 29, 2004 at 8:24 PM / IP Logged
I am sorry, but why? All it would take is a toggle switch of your choice per ign/acc wire, a relay per ign/acc wire. You would also need the push button and a relay for the starter. Then wire the toggles to pass a ground and all the relays like this diagram.
wire a push button start -- posted image.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
harlyneisenmann
Member - Posts: 43
Posted: May 29, 2004 at 8:28 PM / IP Logged
i have no idea what that diagram means that doesnt really help me i need to know what wires go where, also i have no relays just the button and some toggles, also this is on a 89 ford f150.thanks
auex
Posted: May 29, 2004 at 8:31 PM / IP Logged
Then go buy some relays. Depending on the toggle switch you could wire the ignition/acc wires to them directly, mainly if they are capable of handling 30 amps. Also for wire colors read the second post from the top on the forum listing.
harlyneisenmann
Member - Posts: 43
Posted: May 29, 2004 at 8:56 PM / IP Logged
well i was told i didnt need a relay, do i even really need a relay, thanks for you help can any one else help me, i dont know how to read the wire diagram out of my haynes manual i just need to know what wires i need to hook up to the toggles and to the button
auex
Posted: May 29, 2004 at 9:07 PM / IP Logged
Try clicking on the word "Diagrams" at the top of the page. Then click on vehicle wiring information. Then choose your year and make. Then click on the model that applies to you. Since I don't know what type of toggles you have I will not tell you how to wire them for safety reason, if they are too small then you run the risk of setting your truck on fire while driving.
harlyneisenmann
Member - Posts: 43
Posted: May 29, 2004 at 9:27 PM / IP Logged
ok i have 2 20 amp toggle switches and one 60 amp button if know what i have to do will you please tell me if something happens i wont hold you liable or anything i just need some help, do i need more bigger amp toggles, just let me know what i need i also have inline fuses for the toggles and the button i just need to know what to wire i dont know what wire goes where. please help me.
brivalen
Member - Posts: 31
Posted: May 29, 2004 at 10:05 PM / IP Logged
you really need to listen to these guys - you think you can just hook up some switches and be done? NO, you have to energize your ACC wires as well as your IGN and Starter wires. Since none of those wire can be in contact with each other you need relays to make that work.
deviousjoker
Copper - Posts: 102
Posted: May 30, 2004 at 12:15 PM / IP Logged
as far as your push button starter is concerned you need a relay to operate it
30-to your starter motor
85-(-) switch from your push button
86-12v ign.
87-12v.
First Class MECP Installer
harlyneisenmann
Member - Posts: 43
Posted: May 30, 2004 at 3:10 PM / IP Logged
ok there is two wires on the button what goes on the other terminal and do you know what i need for the toggles what amp and what wires go to them for the acc
