I need it to be louder
soccer_aholic
Copper - Posts: 71
Posted: May 31, 2004 at 11:06 AM / IP Logged
Ok. I have a friend who is running a 1 12 inch stroker, off a planet audio PA-2500D. he told me that he just broke 150 db with this set up in his jimmy.
Now I am the most competetive person in the world and I will not let him get away with being louder then I. The weird thing is we are both bought the same amp (planet audio PA-2500D) without knowing it. the only difference is I own an Audiobahn AW1208T.
I need to be able to be louder then him. I just want to know what little things i should do to make sure i get the most out of my system. Anything that will improve my spl will help.
Soccer_aholicI need it to be louder -- posted image.
DYohn
Platinum - Posts: 10,741
Posted: May 31, 2004 at 11:11 AM / IP Logged
Like you said, you have an Audiobahn...
If you want more SPL, get a better woofer with longer throw and better construction and put it into the correct ported enclosure.  Something like an Eclipse Aluminum, an Adire Brahma, a Planet Audio FU, etc.
soccer_aholic
Copper - Posts: 71
Posted: May 31, 2004 at 11:14 AM / IP Logged
At the moment changing the sub is not an option. I know that the Audiobahn is not the best choice for this. it will eventually get changed. I am looking into getting a planet audio FU but not right now. anyways I just want to know what little things i can do. Like my box i am going to use 1 inch mdf instead of 3/4. just things like that.
DYohn
Posted: May 31, 2004 at 11:40 AM / IP Logged
The best you can do is follow the "ultimate SPl bass box" guidelines provided by the manufacturer.  Then be flexible with placement in your vehicle to find the "sweet spot" position for the enclosure where it sounds the best.  1" MDF for the baffle board (where the woofer is mounted) is a good idea.  Be sure your enclosure is well braced and all seams sealed.  Be sure to mount the ports on the same side as the speaker.
soccer_aholic
Copper - Posts: 71
Posted: May 31, 2004 at 1:47 PM / IP Logged
Ok. Do you guys think that I have a good chance of taking my friend in the next spl competition?? He will be running his in a jimmy and i will be running mine in a 1994 eagle talon. Do you think i should hook a cap up? also how much will dynamat do?
Alpine Guy
Platinum - Posts: 2,478
Posted: May 31, 2004 at 3:49 PM / IP Logged
i really doubt that he hit 150, ,  but do everything you can. . and then when it comes to comp time blow him away and make him look silly.  He prolly only hit 135 or so.
bucktussa
Member - Posts: 13
Posted: May 31, 2004 at 6:35 PM / IP Logged
150 with 1 stroker?!?!??  nah...    people need to keep it real.
- 97 Honda Prelude SH
- 3 CVR 10's on Power 1000bd
- Kicker K series components
- Sony 4ch Highs Amp
- Pioneer Premier Deck
- Delphi XM Reciever
- Sony 10 disk changer
dbdraggirl
Copper - Posts: 75
Posted: May 31, 2004 at 6:42 PM / IP Logged
I hit 147.5 with 1 12" Kove Armageddon Z... So it's possibly to get up there in the big numbers with one sub..  Just throwing that in there I need it to be louder -- posted image.
soccer_aholic
Copper - Posts: 71
Posted: June 01, 2004 at 7:51 PM / IP Logged
Does anybody have any suggestions on how to make it louder??? maybe a cap?? dynamat?? things like that?? what dorta things help??
DYohn
Posted: June 01, 2004 at 8:45 PM / IP Logged
Dynamat (or something like it) might help.  The only thing you can really do is build the proper enclosure and go for it.
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
