car system in home?
suicide
Member - Posts: 14
Posted: June 04, 2004 at 11:30 AM / IP Logged
OK so i have subs amps crossovers etc..
my car is in the shop... but i still want bass...
hmmmm
Problem: Running 12volt Equipment in a house..  110 Vac i think...
I don't want to do this [A battery hooked up with a charger that goes into the wall..]
anyone know how to run ur amps stright out of the wall.. i am willing to buy a converter...
just not a battery charger..
thanx
 - suicide
kfr01
Gold - Posts: 2,121
Posted: June 04, 2004 at 11:40 AM / IP Logged
http://www.etronics.com/product.asp?stk_code=pyrps21kx
Something like this works great.  I did this a few years ago in college to combat some loud neighbors.  Nothing like the bass from 2 12" car subs ripping through some thin walls.  :-)
New Project: 2003 Pathfinder
figi
Member - Posts: 13
Posted: June 04, 2004 at 12:06 PM / IP Logged
I am running same stuff , after having several systems , I collected left overs and put all together in my SOFABAD (HEHE)  ,2x12 type R  are giving enough juice while you are watching movie.
 You mention you arleady have equipment , just get power supply and enjoy. If you didnt have , I wouldnt recommend , in overall probably you would end up more than just buying home sysytem ..
Marcin Figura wanna shout Viva Polonia !! yeah .. wszedzie !
DYohn
Moderator - Posts: 10,741
Posted: June 04, 2004 at 12:47 PM / IP Logged
Just be aware of the limited current available in such power supplies.  You are always better off simply buying an amplifier designed for use on 120V (or whatever is the standard in your country) house power.
speedwayaudio1
Silver - Posts: 879
Posted: June 04, 2004 at 1:56 PM / IP Logged
save it for your car it's not worth the trouble. a home system will sound much better in your house. as Dyohn said it will be hard to find a power supply. the biggest power supply I can get is only 40 amps. Thats plenty for a bench top, but not enough for a "system".
Big Dave
Saturday, July 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
