1989 ford expedition door lock problems
rudedog7976
Posted: June 10, 2004 at 12:22 AM / IP Logged
Ok here is the deal i am installing a k9 mundial 2 in a 1998 expedition. Everything was going good until the door locks, I am thinking that the neg pulse on the alarm is too long. When i arm the alarm the door locks rattle i touched the wires with a grounded test light and if i just tap it it is fine but if i hold it there for a sec they rattle so i read the instructions there is no setting to change the length of the pulse is there somthing i can do to shorten the pulse via resistor or somthing any help would be apreciated
draasch
Gold - Posts: 2,172
Posted: June 10, 2004 at 8:52 AM / IP Logged
is it more of a grinding noise????
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Teamrf
Gold - Posts: 1,031
Posted: June 10, 2004 at 9:21 AM / IP Logged
Where are you getting the door lock wires from? It should be a neg. trigger.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
rudedog7976
Posted: June 10, 2004 at 11:31 AM / IP Logged
they are neg trigger, the problem is the neg pulse from the alarm is too long is there any way i can shorten it? the door locks are engaged too long.........
