99 Nissan Altima GLE
pfellner
Posted: June 11, 2004 at 5:33 PM / IP Logged
I've just installed an aftermarket security system (Internet Alarms IAS 100/200) but I need to deactivate or disable the factory "Keyless Entry" system which is interfering with it. The IAS works fine but when I disarm it, it unlocks the doors and sets off the factory system.
I talked to a less than helpful Nissan person at the local dealership who said I could just disconnect the fuse for it. There are 3 separate fuses for it.
Anyone know specifically what needs to be done?
draasch
Gold - Posts: 2,172
Posted: June 11, 2004 at 6:21 PM / IP Logged
OEM Alarm Arm L GREEN/ RED (-) AT "SMART ENTRANCE
OEM Alarm Disarm GREEN/ YELLOW (-) CONTROL TIMER" *
* "Smart Entrance Control Timer" Is A BLUE Module Located Behind The Driver Dash To The Right Of The Steering Column.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
pfellner
Posted: June 11, 2004 at 10:08 PM / IP Logged
Draasch. Thank you for the guidance but I'm not sure what I am supposed to do. I am well versed in electronics but by no means am I a professional. Could you help me out some more and explain what I am to do? Thank you VERY much for your help!
draasch
Gold - Posts: 2,172
Posted: June 11, 2004 at 11:11 PM / IP Logged
take yur door lock wires and tap the wires that i sent you.
if you pulse the factory alarm wires, it will arm and disarm the factory system...
Good Luck
David
Ace Security
813-376-9778
Tampa
pfellner
Posted: June 11, 2004 at 11:24 PM / IP Logged
Thanks David. I'll give it a shot!
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
