Eclipse Door lock/unlock Viper alarm
blindxp
Member - Posts: 19
Posted: June 12, 2004 at 4:13 PM / IP Logged
My eclipse has a (-)unlock and a (-)lock already tapped into from my last alarm. HOWEVER, my Viper installation guide wants :
vehicle(+) lock trigger circuit.
vehicle(-) unlock trigger circuit.
I've never read about any positive lock, its always (-), wtf do I do there?
draasch
Gold - Posts: 2,172
Posted: June 12, 2004 at 4:17 PM / IP Logged
is there more info on those wires???
did it just give you the two wires abouve??/
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
blindxp
Member - Posts: 19
Posted: June 12, 2004 at 4:28 PM / IP Logged
http://bestpricedeverything.com/Wire%20Guide.pdf
I've read that I'm this Negative Type B. I'm assuming so since my last alarm had (-) for lock/unlock anyways.
Thanks for the help
blindxp
Member - Posts: 19
Posted: June 12, 2004 at 4:29 PM / IP Logged
H2/f was already hooked up to a ground wire when I recieved, I don't think it matters since I don't know what car it came off of.... but its more info
blindxp
Member - Posts: 19
Posted: June 12, 2004 at 5:34 PM / IP Logged
Maybe I just won't have keyless entry anymore?
padawan
Copper - Posts: 215
Posted: June 12, 2004 at 5:38 PM / IP Logged
Each Viper lock and unlock wire does 2 things...either it's the (+) lock wire or the (-) unlock wire, depending on what u want it to do...Take the viper's wire that is (-)lock/(+)unlock and tap that into ur Eclipse's (-Lock) wire...Take the viper's wire that is (-)unlock(+)lock and tap it into ur Eclipse's (-) Unlock wire...That's it.
draasch
Gold - Posts: 2,172
Posted: June 12, 2004 at 6:12 PM / IP Logged
hook H2 E and H to ground
and then hook H2G to the unlock wire in the car.
H2D to the lock wire.
Good Luck
David
Ace Security
813-376-9778
Tampa
blindxp
Member - Posts: 19
Posted: June 12, 2004 at 10:42 PM / IP Logged
thanks guys! I'll get to it in the morning and post my success for future searches
padawan
Copper - Posts: 215
Posted: June 12, 2004 at 11:05 PM / IP Logged
Didn't know he had a a unit with built-in door lock relays.
auex
Platinum - Posts: 5,041
Posted: June 13, 2004 at 1:57 AM / IP Logged
Purple to ground, white and brown to nothing. Blue will be -unlock ouput and green will be -lock output. I am not including stripes on the wire colors. The positive lock trigger in the manual is a typo.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Monday, January 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
